Patrick is right. The crate motors rated at 300 hp have made 325(magazine hp) with TTI headers and the M1 dual plane. The truc motor has a slightly bigger cam and if you use the eddy air gap you get a better manifold so I would say you should make 325 real world HP easily. The carb may be just a hair small but not bad.
