Quote: I would like to know the amp draw also because I don't notice a big drain on the battery, but I also have a fairly big amp alt stock from the factory.
I think my factory alt is about 37 amps peak, so 30+ amps on startup would create problems for me. the fan i bought draws 7.5 max
30+ Amps on Startup??
The poster said About 30 Amps on startup, meaning Less. So with your 37 amp peak alt., You would have more then enough power to run the mizer/Hiflow HHR fan. mike
