check anything that rotates. Did the tires flat spot from sitting? I had a incompentent shop that turned some brake drums for me, one was out by 32thousands and the other out 10 it was one of the last things that i checked. what about the driveshaft yolk that goes into thte rear of the trans, is it loose?
