Re: Rancho shock settings?
[Re: codfish]
#435033
08/11/09 07:17 PM
08/11/09 07:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have the 9 way adjustables. #99116
Nothing on their site, and the only thing in the box, other than the shocks, were decals.
What do the settings, 1 thru 9, represent? Is setting #1 the easiest to compress, or extend?
I understand 70/30, 60/40, etc., but not these.
thanks codfish
On most shocks you will be adjusting the extension BUT it might be tightening the compression some also, the higher the number the harder it is to pull apart. Maybe someone that runs those will verify this
