Russ,
The car will run 10.30's in 2000 or less DA on Radials. My M/T Radials lasted 52 passes!! I bought bias slicks Friday and they are a sure tenth plus slower. I thought I'd cover the 10.50 index by pulling the exhaust, not the case. Just wanted to pass the info.
Gotcha ---- I have MT's on mine and I should have stayed with the Hoosier radials like I had on the 64. I had good luck with those and ran them for a couple of years before they gave out. However that was on a lighter car and it was only a 9" tire and not a 10.5 so that could have helped with the longevity.
Russ
