I don't think that the ultra bell is any larger than the 727 bell and we know that it will fit. If I were buying new I would consider the ATI case/bell. I do run JW bells, but had problems with their "wheel". This was with 850Hp though. Run a Reactor alum wheel now.
I will be running a JW Glide with "The Wheel " what kind of problems will I be encountering ?
I had one loose a section of ring gear and broke the ultra bell, ripped through the headers and poked a hole in the oil pan. Diaper on the engine saved the car. I took it out and it was cracked at every weld.
