Nothing wrong with the poly mounts though, just I would rather replace it with a non-wear item.
You probably wouldn`t see any wear on them in your lifetime.
Probably. After 6 years of daily driving the poly mounts still look like new. No regrets, I would just like to try the solid mounts in my car to feel if they'd make an ounce of difference over the poly mounts. Though mine's an original small block car with a front sway bar. I'm sure a big difference in front end rigidity there than a big block car with that huge cutout on the passenger inner fender.
