Think they have parts for 41' plymouth?
His "kits" consist of caliper brackets, the bearing spacer, and bolts to mount the caliper bracket. Then he gives you a list of parts and numbers from several auto parts chains so you can save money and buy your parts where ever you find the best prices. You do have to retap the bottom spindle bolt holes to a 5/8" fine thread. (He used to offer to do that for you for a fee, if you send him your spindles.) The 39 was the "old" style spindle, and when I was done, the spindle bearing nut and cotter key was real close to the end of the spindle, but it seemed to work OK.
I have install his kits on a 39 Plymouth and a 47 plymouth, both of which had different spindles and contained different parts and different lists. I think he can make you a special kit for a specific application if you need one. He will work with you to be sure everything works. I would do business with him again. Gene
