Every time I restore a 70-71 e body rally light bar, the lens are always warped, cracked and sometimes missing.
The only way to restore these bars correctly is to remove the lens and in some cases I end up breaking good ones.
I decided to try and make some. I could not find the correct blue/green color plastic so I purchased some clear
plastic sheet and painted it myself. The flash is making the lens look blue but it is not.
It's my first batch so I still have lots of refining to do.
Since I cannot locate the exact size black rivets, I made the holes for some rivets I presently have in stock.
The best color match is the one that is next to the original warped one.I counted the coats I put on each one
so I know the formula. Your thoughts?
Jules
