IMHO you have a couple issues, smallish carb and small headers and the 60' seems a little slow. At you're weight it should be in the 6s in the 1/8 now. My old hydraulic cammed, pump gas 340 went mid 7.20s with a best 1.533 60', it normally went 1.55-1.57. 69 Dart, 3300#, 9.5" 4400 converter with 4.30 gears. If you're chassis was sorted out you'd be there now .
He'd have to be a real chassis whiz to hit 10s @ 117.
