have one ging together right now. biggest expense in cutting the crank is the seal area and slinger. were using a 318 piston and a 307 olds rod (left over from a stock eleminator build up) the crank just touchs the piston. we will cut them for clearence and rebalance. the piston sits bout .04 in the hole.
