Sure colors can change over the years to some extent, both sunlight and heat changes it the most, but sunlight can be ruled as a minor factor in most engine examples because they are under the hood. I have 3 complete turquoise engines and allot of original paint to look at on all areas (both high heat areas like intakes and lower heat areas like accessory brackets, etc.) It's pretty easy to determine which areas show the true original coloring.
