You need to remove the storage bin from lower part of console,there is a few plastic screws on each side then you can get to screws that hold on bezel around radio. Then if you look above radio you will see 2 access plugs that need to be removed and screws removed,then push up on top piece and you will be able to get to the other screws that hold bezel around radio
Thanks a lot man. Really appreciate that!
