If you call Wilwood they will tell you to use there adjustable valve in the line going to the rear brakes.
On a race car with big slicks on the rear and skinnies on the front.... I wouldnt put the adjustable valve on the rears... front yes... reason why... a adjustable prop valve is nothing more than a delay, all the pressures will equalize after a period of time depending on how the valve is set, so with skinnies up front and you put the valve in the rear you are slowing the fluid to the rears and giving full fluid to the front giving the front all/most of the load on the tires... they just arent big enough to carry that load If this was a street car with equal size tires then yes I would put it on the rears to slow the tires from locking up as the frontend dives on braking and the rear gets light
Makes sense to me.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
