I have a 1979 dodge W150 swb PALOMINO. It was an odd-ball truck, as it was fairly loaded up, but came from the factory with a 4spd and no a/c. Attached is a pic of the window sticker. It is in the process of a restoration, and I have added factory a/c to it allong with the big bolt pattern axles to it with the 5 slot wheels. The VIN is as follows.... W14JT9S195981. This truck came out a Wrecking Yard in Northern CA, and I am glad that I saved her!! I have a couple of these trucks now, and am getting another PALOMINO from VA that is also a 4wd.
