with my print out of the program how about; 60.7 instant center length and10.5" I.C. 100% antisquat This is as close as I can get on the car. top axle bracket top hole top frame bracket bottom hole. bottom axle bracket top hole and bottom frame bracket bottom hole and bottom bar is still inclined about 2 degrees
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
