To my knowledge...yes.
The example you use are two RR built at different plants. The VIN's would be unique in that the 7th digit is different (Lynch Rd vs St. louis plant).
It is possible but a very remote possibility. Remember, some plants built different body style at the same location and the last 6 digits of the vin were sequential as they were assigned to the vehicles.
Frank
Yes it is possible. I asked this same question a while back and someone posted a couple of VIN's that were really close (or the same, ???) from two different assembly plants. The same final sequence numbers should have happened THOUSANDS of times I would think if they all started with 0000001 but the body/model, engine match up would be coincidental and a given it would never have the same plant code
MikeR
