What would a reasonable safe boosted HP limitation be for a stock 360 cast crank ?
Do Magnum cranks have any hp limitation differences over traditional 360 LA cranks?
Curious about using a cast crank in a small single turbo street/strip application.
360 buildup would be very similar to the mild combo that topfueldart has with his turbo 318.
topfueldart combo
PT6776SP, .96 AR turbo or something similar.
I am not looking for ridiculous horsepower but would anticipate that it would be seeing 10-15 psi of boost and in the neighborhood of 500-550+ hp
Fairly realistic numbers given 4500 ft elevation and tuning.
Plausible or ticking time-bomb?
I know the most sensible thing to do is go forged...just curious about the el cheapo first option.
topfueldart's 318
