For a primarily street driven car I would run the 3.55's.Any more than that will not give you much if any E.T. gain on drag radials but your driveability will suffer unless you like spinning 3000-3500 rpm at 60-70mph on the freeway. The stroker makes so much torque you don't need to rpm it to death.Let the torque move you.
