I run that exact setup....20" cal-tracs from a mid 60's B-body with 20" front segment mono-leafs. You need the extended Mopar performance spring hangers that are meant for use with Superstock springs (those also have a 20" front segment).
If you want to use a 22" front segment spring then you need to do as blues_cuda mentioned above.
