I do have an old set of valve covers.Thinking of cutting the tops off so i can run it without oil running out all over the exhaust mainfolds. I did spin push rods and could not feel any of them being loose ones that were on base of cam lobe at least. I need to hook up my remote starter and tap motor over to check the ones that valves were open. Suppose you could be right just a little loose could do it.
