Stock tank with a sump welded in, Aeromotive street rod pump (their little street pump), Russell inline filter b/t pump and tank, Aeromotive 2 port regulator mounted right at the carb. -8 line up to the regulator, -6 lines to the bowls. It's a simple dead headed system that's worked flawless for many years. CHIP
