I still do it the old way, clean coffee can, dump a qt of 30 wt oil in and I submerge the piston past the pin and let it sit then install using a tapered compressor. I use assebly lube on the bearing. The engine may sit for a week or better before install this way gives me peace of mind but may not be state of the art.
I have never lost an engine doing this.
