This subject often leads to heated debate, the stock tapered bearing is superior to the Green bearing but many use the Greens because they're too lazy to learn how to adjust the tapered bearings.
Ain't that the truth? and the thing oncee they are adjusted it isn't something that has to be repeated in the forseeable future.
Why do you want to change bearings? If they aren't galled or pitted clean them up and pack them with a good wheel bearing compatable grease, install new inner axle seals, put the axles in, adjust the endp play and button it up. http://www.moparts.org/Tech/Archive/axle/12.html
