The best - fastest, easiest, way I have found to do 1 man bleeding is with a "Mighty-Vac". If you by the Mighty Vac Kit, it will come with everything you need to Vacuum bleed your brakes - resevoir, hoses, and the little nipple that snaps on to the bleeder screw. Doing them one at a time ( and it doesn't make any difference where you start ) you can do the entire system in 1/2 hour. No drips, no runs, no air in your lines - and when your done you have a great shop tool for many other purposes.
Fastest 300
