You will be spending so much on building your Hemi that it will be self defeating and foolish to skimp on something as crucial as the block.
I made that mistake and I have a $1000 boat anchor.
If the block was not properly heated when the cast iron welding was performed, the block will come apart.
I've also seen plenty of blocks that should have never been sleeved end up sleeved.
Before the Atlanta Connection closed, I ended up buying the last block Lawrence Roundtree had and that's what I should have done in the first place.
