Re: OK Which Mini Starter?
[Re: 64Post]
#362832
07/01/09 01:24 PM
07/01/09 01:24 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
All you guys telling this member what you are using on your 440 , unless its a low deck stroked to 440 cubes , is TOTALLY USELESS INFORMATION , headers and minis fit fine on RB blocks , completely DIFFERENT STORY on a low deck , been there, smashed the tubes to prove it .
And with that said, my combo is a 450" B block, TTI 1-3/4" headers, 130T flywheel, and Robb starter. No fitment issues whatsoever. I didn't have to clearance anything.
Headers play a huge part in this members decision , the mini starter is WIDER than the std gear reduction starter ( at least the first one I used was), if the header isn't designed with that in mind a mini is not going to fit .
