Retaped the under the dash wiring and installed the dash. Installed the gauges and dash pad also. Took me forever to decide on the gauges. The only thing bad about the sun tach is you have to buy a 60.00 msd tach adapter if you run the msd ignition, which I am.
Just started reading your build post,,looking great,,,FYI,,I just had to buy a tach adapter for my old Sun,,$80.00+. Don't let that wreck your build budget!! Keep up the good work. I'll keep watching.
If you like drag racing, support your local track.
