Holes allready too large to camshaft. Can be restricted also by drilling a new .093 hole in the cam bearing and lining up new hole to block. That can only be done to 1-3-5 cam bearings unless you are going to oil the rockers with an external line. 2 and 4 cam bearings feed the rockers normally.
