Yes
FWIW If your looking for a spare you'll know visually if it's the one, they are the only two belts I've seen with the spring wrapped around a pin secured with a snapring... & the C body floor bracket is different so you need the E body bracket...
The Fact that Mike Ross (BEA is now reproducing these makes it a little easier.. Not cheap but his belts are super nice.. Not for the Concourse crowd but great for someone that wants it 95%+ visually correct & brand new...
