Quote: I forgot to mention..... I wanna run in the 9's ALL day long on motor and any heat is my goal meaning I dont want a 10.2 car and in october run a 9.90.... hope this helps..... I also have been thinking about a B1 setup... just trying to find the simplest setup to stuff into an A body car...
I have seen some of your b1 pics and some of you have braided lines in front of the heads going down into the block or something...
9.90 at what weight? any of those heads will do that with 540 ci. Do you have a short block already? Decide from that.
