Here is a picture of mine during mock-up. I ended up using a standard B/RB tube which I heated and bent in several places to snake up around the headers. I welded a tab to the tube and it bolts to the top header flange bolt. I had to get the bends "just right" so the stick would slide in easily.
Works great.
Stan
