I think Robert was trying to say that on the backside of that headlight switch (behind the dash pannel or under the dash) there is a spring loaded button. Fiddle around with it and try to insert the whole rod again. To remove that rod, you must push in the button, so maybe it got stuck. They arent that expensive to replace, and any parts store should have them. Any ?'s just PM me.
Patrick
72 Dart Swinger 360 Project
