We should get this added to the Best of Moparts, it gets old giving out the info.... Anyway, the dimensions are as follows:
From the edge of the first trunk body line (NOT the edge the finish panel would fasten too) the stripe starts at 4-3/4". Also, the stripe follows the crown of the trunk, it is NOT straight across! The first stripe is 1/4", then 1/2" gap, then 2-1/2" second stripe, then 1/2" gap, then another 2-1/2" stripe, then 1/4" gap, then the last 1/4" stripe. Also, if you look at the edge of the quarter panel at the low end where the edge of the bumper sits the stripe is 1/2" away from the start of the radius. Also, you can measure the first stripe from the edge of the quarter panel where the tail light bucket goes to 8-3/4". Just buy the vinyl stripe!
JB Rhinehart, Realist
A-Body's RULE!
