Have you had it aligned? You need to fully check the suspension. Jack it up put the front on jackstands and have someone move the wheel while you look at every joint and bushing from 6 to 12 inches away. Yank on the centerlink up and down to see if the idler or pitman is bad.
Check the bolts on everything. Start with the steering box. Check and adjust the wheel bearings.
