Hum...check and make sure the caliper is mounted correctly. Lube the pins etc. Also disconect the hose to the caliper & rebleed, push the piston back in & then bleed again. Piston should move back to the rotor. Just a few things I have run into. I have bought new defective calipers that were stuck & bad hoses. God luck
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
