I have some questions about the poly 318.
Does anything from the la engines interchange with the poly? I think the distributor will??
Same timing chain? And also I found a very rough
'55 dodge in a junkyard the other week which was believed to have it's original poly styled engine.
It had the 'super red ram" valve covers on it. Will those work on a poly 318???
