Original seals are IPC 5686526 for the oil seal & IPC 5688229 for the dust seal. You will find them on the web in multiple places all showing discontinued. I did find online the oil seal N.O.S. at a surplus reseller, but no dust seal.
Nitrousin, I had found that and in fact it is in my cart. Rock Auto also carries the same brand & part number. I have not pulled the trigger for this reason. Nothing I've found verifies it as for the 7/8" shaft. I've already been through that long list of applications that it "fits" with Napa, O'Reilly, Advance Auto, & Autozone. They all say they have it and it fits. But when you get hands on it, it is the seal for 3/4" input. The Gates kit I listed before is so far the only verified correct items.
Thank you for the time you spent looking and responding.
