I still have the large-face 0-15 PSI Moroso I bought 25 years ago, but the problem is everything I run now are radials which require higher pressures
I picked up one of these quite a while ago:
https://www.jegs.com/i/JEGS/555/65035/10002/-1 and found it to be very accurate, considering I cross-checked it against two other gauges across a range of pressures and they were surprisingly consistent
The only issue was I dropped it once pretty hard and it lost its mind. I purchased another one, only this time I also got the Jeg's extended warranty for 3 years which is a simple "if it's broke, they replace it" deal for another $14; just checked and it's good for another 2 years
