That depends on where the engine is going to sit.
On my Dakota clip from a Dakota that had a 318 FI (5.2?) my engine had to move back about 4 inches so I used the original style motor mounts and with a piece of flat plate to extend the engine mounting surface by the required amount.
Much to my surprise (shock) the top and bottom original moulded rad hoses fit the Dakota rad perfectly.
