Id run long and hard from an 84. Had one new and was dumb enough to try another used 84 a few years later.
The 84 4 lug soon to be replaced by 5 lug cam eating sub standard clutch and plastic eating clutch adjuster pos then when you do put a good clutch in you can hole the transmission quickly. An old pinto could take more abuse.
In the slow car year of 1984 these things were the slowest of the slow I cant recall anything it would hang with and all while watching the front brake pads smoke and sizzle like a charcoal grill just trying to stay in the group even on braking.
Early years of the rubber band tires in which one bad pot hole and your going to need both tires on that side you hit the hole. I bought it because it looked sporty and was a dodge. Now the rice powered... twin stick turbo colt I bought that same year was 10x the car.
Best fair offer IMO is no offer.
