My 24 Ft Pace Shadow 10,000Lb rated weighed right at 8600 lbs. loaded on the two axles, it added 700 lbs. on the trucks rear axle weight and removed 300 lbs. from the front axle weight, that was with my old pump gas Duster street and strip car that weighed 3450 lbs. with me in it shruggy
