Originally Posted by 2boltmain
I believe the adjuster WITHOUT the locking nut is the OEM adjuster. They are an interference fit designed to not use a locking nut.
And when the interference fit becomes loose, only way to save the rocker is to run a tap through the threads and use an adjuster that needs a locknut.
The INTERNET, the MISinformation superhighway
