Originally Posted by moparx
Originally Posted by mickm
Originally Posted by sam64
It's the contacts that the plunger connects to complete the circuit. yes it is repairable.You can get the plunger/contact kit on Amazon for 14.00
plus, it's a super easy thing to do !
also, you may just find a little polishing of the contacts is all it needs. i have run into that several times over the years.
beer
^^^ this ...
Mick you can order the plunger but in the mean time pull it and open up the solenoid , you'll probably see it's pitted , clean it up and that may be all it needs?
running up my post count some more .
