Holley made a lot more 1970 six pack carbs than you listed, there are automatic carbs for the 49 states beside CA and automatic CA carbs also, same thing on the stick shift carbs.
You can run any and all of the different ones you have access to on any six intake and they will work as long as you don't care if they are the correct year and part numbers for you car twocents up work shruggy
