So its VERY EXPENSIVE and the manufacturer is lying about its true range and true recharge time? Same promotional template as 10,20 30, 40 etc. years ago. But it will save the planet because its zero emissions...... Usually, during a discussion like this someone will chime in with a reply to all the factual shortcomings of every EV- and that reply is "They will figure it out." Who is they? Worldwide- billions maybe hundreds of billions of $$ has been spent on figuring it out and the result is- No one has figured out anything. Battery is still dangerous to build, dangerous to own - expensive and provides unacceptable performance.
