Diplomat - yes , let me know what you figure out.
BDW - will check the gas pedal idea out. If you don’t have to use the new pedal, that would be good. Otherwise, I don’t think I would want to use a new pedal. I was trying to keep the car look as stock as possible and I already are needing to use the new console (had to modify the hump for the bigger trans.).
