The carbs I have seem to work really well so far but are leaking at a few different areas...
I'd just as soon rebuild them with new kits but in researching it I'm not sure what I need to purchase...
These carbs have the metering blocks installed in the secondary's and the longer fuel feed tubes...
Anyone have any rebuild kit numbers I can use to get everything I need?
The choke horns have been removed so no carb numbers are there...
In searching Holley's website it seems the original part number was 0-4224 but I haven't been able to find any rebuild kits for this part number...
