IMO pretty simple choice, A1 as high winding SB's are their bread and butter. They would want a dyno sheet or at the very least some previous performance numbers and details. But I can tell you the dyno sheet is a much better start. Those two engines will require two different converters, just to much stroke difference to not require two.
