I'll cut airhorn gaskets. Base gaskets should be ok other than the mounting holes and or throttle holes. Other gaskets should be standard stuff.
No I meant are the gaskets installed between the bowl and metering block and metering block and carb body, they didn't look like it in the picture and that will add a small amount to the carb overall width.
and another question , what air cleaner are you planning on , that is going to need to be modified too .
What did you have to whittle off the carbs there?
I'm not familiar with what those carbs are off originally, Ford truck application?
They should work, what size engine are you running this on?
